建立黑名单,防范钓鱼网站
- #ifdef _DEBUG
- #define new DEBUG_NEW
- #undef THIS_FILE
- static char THIS_FILE[] = __FILE__;
- // CAboutDlg dialog used for App About
- class CAboutDlg : public CDialog
- CAboutDlg();
- // Dialog Data
- //{{AFX_DATA(CAboutDlg)
- enum { IDD = IDD_ABOUTBOX };
- //}}AFX_DATA
- // ClassWizard generated virtual function overrides
- //{{AFX_VIRTUAL(CAboutDlg)
- protected:
- virtual void DoDataExchange(CDataExchange* pDX); // DDX/DDV support
- //}}AFX_VIRTUAL
- // Implementation
- protected:
- //{{AFX_MSG(CAboutDlg)
- //}}AFX_MSG
- DECLARE_MESSAGE_MAP()
- CAboutDlg::CAboutDlg() : CDialog(CAboutDlg::IDD)
- //{{AFX_DATA_INIT(CAboutDlg)
- //}}AFX_DATA_INIT
- void CAboutDlg::DoDataExchange(CDataExchange* pDX)
- CDialog::DoDataExchange(pDX);
- //{{AFX_DATA_MAP(CAboutDlg)
- //}}AFX_DATA_MAP
- BEGIN_MESSAGE_MAP(CAboutDlg, CDialog)
- //{{AFX_MSG_MAP(CAboutDlg)
- // No message handlers
- //}}AFX_MSG_MAP
- END_MESSAGE_MAP()
- // CIehookDlg dialog
- CIehookDlg::CIehookDlg(CWnd* pParent /*=NULL*/)
- : CDialog(CIehookDlg::IDD, pParent)
- //{{AFX_DATA_INIT(CIehookDlg)
- // NOTE: the ClassWizard will add member initialization here
- //}}AFX_DATA_INIT
- // Note that LoadIcon does not require a subsequent DestroyIcon in Win32
- m_hIcon = AfxGetApp()->LoadIcon(IDR_MAINFRAME);
- void CIehookDlg::DoDataExchange(CDataExchange* pDX)
- //{{AFX_DATA_MAP(CIehookDlg)
- // NOTE: the ClassWizard will add DDX and DDV calls here
- //}}AFX_DATA_MAP
- BEGIN_MESSAGE_MAP(CIehookDlg, CDialog)
- //{{AFX_MSG_MAP(CIehookDlg)
- ON_WM_SYSCOMMAND()
- ON_WM_PAINT()
- ON_WM_QUERYDRAGICON()
- ON_BN_CLICKED(IDC_KAISHI, OnKaishi)
- //}}AFX_MSG_MAP
- END_MESSAGE_MAP()
- // CIehookDlg message handlers
- BOOL CIehookDlg::OnInitDialog()
- CDialog::OnInitDialog();
- // Add "About..." menu item to system menu.
- // IDM_ABOUTBOX must be in the system command range.
- ASSERT((IDM_ABOUTBOX & 0xFFF0) == IDM_ABOUTBOX);
- ASSERT(IDM_ABOUTBOX < 0xF000);
- CMenu* pSysMenu = GetSystemMenu(FALSE);
- if (pSysMenu != NULL)
- CString strAboutMenu;
- strAboutMenu.LoadString(IDS_ABOUTBOX);
- if (!strAboutMenu.IsEmpty())
- pSysMenu->AppendMenu(MF_SEPARATOR);
- pSysMenu->AppendMenu(MF_STRING, IDM_ABOUTBOX, strAboutMenu);
- // Set the icon for this dialog. The framework does this automatically
- // when the application's main window is not a dialog
- SetIcon(m_hIcon, TRUE); // Set big icon
- SetIcon(m_hIcon, FALSE); // Set small icon
- // TODO: Add extra initialization here
- return TRUE; // return TRUE unless you set the focus to a control
- void CIehookDlg::OnSysCommand(UINT nID, LPARAM lParam)
- if ((nID & 0xFFF0) == IDM_ABOUTBOX)
- CAboutDlg dlgAbout;
- dlgAbout.DoModal();
- CDialog::OnSysCommand(nID, lParam);
- // If you add a minimize button to your dialog, you will need the code below
- // to draw the icon. For MFC applications using the document/view model,
- // this is automatically done for you by the framework.
- void CIehookDlg::OnPaint()
- if (IsIconic())
- CPaintDC dc(this); // device context for painting
- SendMessage(WM_ICONERASEBKGND, (WPARAM) dc.GetSafeHdc(), 0);
- // Center icon in client rectangle
- int cxIcon = GetSystemMetrics(SM_CXICON);
- int cyIcon = GetSystemMetrics(SM_CYICON);
- CRect rect;
- GetClientRect(&rect);
- int x = (rect.Width() - cxIcon + 1) / 2;
- int y = (rect.Height() - cyIcon + 1) / 2;
- // Draw the icon
- dc.DrawIcon(x, y, m_hIcon);
- CDialog::OnPaint();
- // The system calls this to obtain the cursor to display while the user drags
- // the minimized window.
- HCURSOR CIehookDlg::OnQueryDragIcon()
- return (HCURSOR) m_hIcon;
- //开始得到IE窗口
- void CIehookDlg::OnKaishi()
- skaishi=AfxBeginThread(kaishi,NULL);
- UINT kaishi(LPVOID lParam)
- HWND zwnd;
- HWND hwnd1,hwnd2;
- HWND anniuwnd;
- HWND editwnd;
- //ToolbarWindow32
- int i=0;
- CString sn,s1;
- CRect qr;
- for(;;)
- Sleep(10);
- zwnd=::GetForegroundWindow();//得到IE主窗口
- TCHAR szClassName[_MAX_PATH];
- ZeroMemory(szClassName,_MAX_PATH*sizeof(TCHAR));
- ::GetClassName(zwnd,szClassName,_MAX_PATH);
- sn.Format("%s",szClassName);
- sn.Replace(" ","");
- if(sn=="IEFrame")//如果是IE
- hwnd1=::FindWindowEx(zwnd,NULL,_T("WorkerW"),NULL);
- hwnd2=::FindWindowEx(hwnd1,NULL,_T("ReBarWindow32"),NULL);
- hwnd1=::FindWindowEx(hwnd2,NULL,_T("ComboBoxEx32"),NULL);
- anniuwnd=::FindWindowEx(hwnd1,NULL,_T("ToolbarWindow32"),NULL);
- hwnd2=::FindWindowEx(hwnd1,NULL,_T("ComboBox"),NULL);
- editwnd=::FindWindowEx(hwnd2,NULL,_T("Edit"),NULL);
- if(editwnd!=NULL&&i==0)
- char sz[255];
- ::SendMessage(editwnd,WM_GETTEXT,255,(LPARAM)sz);
- sn.Format("%s",sz);
- sn.Replace("//","`");
- AfxExtractSubString(s1,sn,0,'/');
- s1.Replace("`","//");
- //这里插入通讯
- if(s1!="http://www.baidu.com"&&s1!="about:blank")//如果不是指向的地址
- sn.Format("http://www.baidu.com",sz);//修改为指向的地址
- char *ss=sn.GetBuffer(0);
- ::SendMessage(editwnd,WM_SETTEXT,255,(LPARAM)ss);
- ::GetWindowRect(anniuwnd,qr);
- SetCursorPos(qr.left+15,qr.top+8);
- ::mouse_event(MOUSEEVENTF_ABSOLUTE|MOUSEEVENTF_LEFTDOWN|MOUSEEVENTF_LEFTUP,0,0,0,0);
- ExitThread(0);
