燕狂徒写的驱动挂钩,限制磁盘只读, 用于保证涉密计算机的稳定,相当于将磁盘变成ROM
#include "ntddk.h"
#include <srb.h>
#include <scsi.h> #define DRIVERNAME "OnlyRead(GongXiPeng!)" // for use in messages typedef struct tagDEVICE_EXTENSION {
PDEVICE_OBJECT DeviceObject; // device object this extension belongs to
PDEVICE_OBJECT LowerDeviceObject; // next lower driver in same stack
PDEVICE_OBJECT Pdo; // the PDO
IO_REMOVE_LOCK RemoveLock;
} DEVICE_EXTENSION, *PDEVICE_EXTENSION; VOID RemoveDevice(IN PDEVICE_OBJECT fdo);
NTSTATUS CompleteRequest(IN PIRP Irp, IN NTSTATUS status, IN ULONG_PTR info);
NTSTATUS DispatchForSCSI(IN PDEVICE_OBJECT fido, IN PIRP Irp);
NTSTATUS AddDevice(IN PDRIVER_OBJECT DriverObject, IN PDEVICE_OBJECT pdo); NTSTATUS DispatchAny(IN PDEVICE_OBJECT fido, IN PIRP Irp);
NTSTATUS DispatchPower(IN PDEVICE_OBJECT fido, IN PIRP Irp);
NTSTATUS DispatchPnp(IN PDEVICE_OBJECT fido, IN PIRP Irp);
NTSTATUS DispatchWmi(IN PDEVICE_OBJECT fido, IN PIRP Irp);
ULONG GetDeviceTypeToUse(PDEVICE_OBJECT pdo);
NTSTATUS StartDeviceCompletionRoutine(PDEVICE_OBJECT fido, PIRP Irp, PDEVICE_EXTENSION pdx);
NTSTATUS UsageNotificationCompletionRoutine(PDEVICE_OBJECT fido, PIRP Irp, PDEVICE_EXTENSION pdx); VOID DriverUnload(IN PDRIVER_OBJECT fido); NTSTATUS
DriverEntry(
IN PUNICODE_STRING RegistryPath
int i;
KdPrint(("准备驱动加载"));
UNREFERENCED_PARAMETER(RegistryPath);
DriverObject->DriverUnload = DriverUnload;
DriverObject->DriverExtension->AddDevice = AddDevice;
for (i = 0; i < IRP_MJ_MAXIMUM_FUNCTION; ++i)
DriverObject->MajorFunction = DispatchAny;
DriverObject->MajorFunction[IRP_MJ_POWER] = DispatchPower;
DriverObject->MajorFunction[IRP_MJ_PNP] = DispatchPnp;
DriverObject->MajorFunction[IRP_MJ_SCSI] = DispatchForSCSI; return(STATUS_SUCCESS);
} VOID DriverUnload(IN PDRIVER_OBJECT DriverObject)
{ // DriverUnload
PAGED_CODE();
//UNREFERENCED_PARAMETER(DriverObject);
KdPrint((DRIVERNAME " - Entering DriverUnload: DriverObject %8.8lX/n", DriverObject));
} NTSTATUS AddDevice(IN PDRIVER_OBJECT DriverObject, IN PDEVICE_OBJECT pdo)
{ // AddDevice
NTSTATUS status;
PDEVICE_OBJECT fido;
PDEVICE_EXTENSION pdx;
PDEVICE_OBJECT fdo; PAGED_CODE(); status = IoCreateDevice(DriverObject, sizeof(DEVICE_EXTENSION), NULL,
GetDeviceTypeToUse(pdo), 0, FALSE, &fido);
if (!NT_SUCCESS(status))
{ // can't create device object
KdPrint((DRIVERNAME " - IoCreateDevice failed - %X/n", status));
return status;
} // can't create device object
pdx = (PDEVICE_EXTENSION) fido->DeviceExtension;
do
{ // finish initialization
IoInitializeRemoveLock(&pdx->RemoveLock, 0, 0, 0);
pdx->DeviceObject = fido;
pdx->Pdo = pdo;
//将过滤驱动附加在底层驱动之上
fdo = IoAttachDeviceToDeviceStack(fido, pdo);
if (!fdo)
{ // can't attach
KdPrint((DRIVERNAME " - IoAttachDeviceToDeviceStack failed/n"));
status = STATUS_DEVICE_REMOVED;
} // can't attach
//记录底层驱动
pdx->LowerDeviceObject = fdo;
//由于不知道底层驱动是直接IO还是BufferIO,因此将标志都置上
fido->Flags |= fdo->Flags & (DO_DIRECT_IO | DO_BUFFERED_IO | DO_POWER_PAGABLE);
// Clear the "initializing" flag so that we can get IRPs
fido->Flags &= ~DO_DEVICE_INITIALIZING;
} while (FALSE); // finish initialization if (!NT_SUCCESS(status))
{ // need to cleanup
if (pdx->LowerDeviceObject)
IoDetachDevice(pdx->LowerDeviceObject);
IoDeleteDevice(fido);
} // need to cleanup return status;
} // AddDevice ///////////////////////////////////////////////////////////////////////////////
// GetDeviceTypeToUse returns the device object type of the next lower device
// object. This helps overcome a bug in some Win2K file systems which expect the
// topmost FiDO in a storage stack to have a VPB and, hence, to have been created
// with a type such as FILE_DEVICE_DISK.
#pragma PAGEDCODE
{ // GetDeviceTypeToUse
PDEVICE_OBJECT ldo;
ULONG devtype;
ldo = IoGetAttachedDeviceReference(pdo);
if (!ldo)
return FILE_DEVICE_UNKNOWN;
devtype = ldo->DeviceType;
ObDereferenceObject(ldo);
return devtype;
} // GetDeviceTypeToUse ///////////////////////////////////////////////////////////////////////////////
#pragma LOCKEDCODE // make no assumptions about pageability of dispatch fcns
{ // DispatchAny
NTSTATUS status;
PIO_STACK_LOCATION stack; #if DBG
static char* irpname[] =
"IRP_MJ_CREATE",
"IRP_MJ_CREATE_NAMED_PIPE",
"IRP_MJ_CLOSE",
"IRP_MJ_READ",
"IRP_MJ_WRITE",
"IRP_MJ_QUERY_INFORMATION",
"IRP_MJ_SET_INFORMATION",
"IRP_MJ_QUERY_EA",
"IRP_MJ_SET_EA",
"IRP_MJ_FLUSH_BUFFERS",
"IRP_MJ_QUERY_VOLUME_INFORMATION",
"IRP_MJ_SET_VOLUME_INFORMATION",
"IRP_MJ_DIRECTORY_CONTROL",
"IRP_MJ_FILE_SYSTEM_CONTROL",
"IRP_MJ_DEVICE_CONTROL",
"IRP_MJ_INTERNAL_DEVICE_CONTROL",
"IRP_MJ_SHUTDOWN",
"IRP_MJ_LOCK_CONTROL",
"IRP_MJ_CLEANUP",
"IRP_MJ_CREATE_MAILSLOT",
"IRP_MJ_QUERY_SECURITY",
"IRP_MJ_SET_SECURITY",
"IRP_MJ_POWER",
"IRP_MJ_SYSTEM_CONTROL",
"IRP_MJ_DEVICE_CHANGE",
"IRP_MJ_QUERY_QUOTA",
"IRP_MJ_SET_QUOTA",
"IRP_MJ_PNP",
UCHAR type;
#endif
stack = IoGetCurrentIrpStackLocation(Irp);
#if DBG
type = stack->MajorFunction;
if (type >= IRP_MJ_MAXIMUM_FUNCTION)
KdPrint((DRIVERNAME " - Unknown IRP, major type %X/n", type));
KdPrint((DRIVERNAME " - %s/n", irpname[type]));
#endif
// Pass request down without additional processing
status = IoAcquireRemoveLock(&pdx->RemoveLock, Irp);
return CompleteRequest(Irp, status, 0);
IoSkipCurrentIrpStackLocation(Irp);
status = IoCallDriver(pdx->LowerDeviceObject, Irp);
IoReleaseRemoveLock(&pdx->RemoveLock, Irp);
return status;
} // DispatchAny ///////////////////////////////////////////////////////////////////////////////
#pragma LOCKEDCODE
{ // CompleteRequest
Irp->IoStatus.Status = status;
Irp->IoStatus.Information = info;
IoCompleteRequest(Irp, IO_NO_INCREMENT);
return status;
} // CompleteRequest NTSTATUS
USBSCSICompletion( IN PDEVICE_OBJECT DeviceObject,
IN PIRP Irp,
IN PVOID Context )
PIO_STACK_LOCATION irpStack;
PSCSI_REQUEST_BLOCK CurSrb;
PCDB cdb;
UCHAR opCode;
PMODE_PARAMETER_HEADER modeData;
pdx = ( PDEVICE_EXTENSION )DeviceObject->DeviceExtension;
IoAcquireRemoveLock(&pdx->RemoveLock,Irp);
irpStack = IoGetCurrentIrpStackLocation( Irp ); CurSrb=irpStack->Parameters.Scsi.Srb;
cdb = (PCDB)CurSrb->Cdb;
opCode=cdb->CDB6GENERIC.OperationCode;
if(opCode==SCSIOP_MODE_SENSE && CurSrb->DataBuffer
&& CurSrb->DataTransferLength >=
sizeof(MODE_PARAMETER_HEADER))
KdPrint(("SCSIOP_MODE_SENSE comming!/n"));
modeData = (PMODE_PARAMETER_HEADER)CurSrb->DataBuffer;
modeData->DeviceSpecificParameter |= MODE_DSP_WRITE_PROTECT;
} if ( Irp->PendingReturned )
IoMarkIrpPending( Irp );
IoReleaseRemoveLock(&pdx->RemoveLock,Irp);
return Irp->IoStatus.Status ;
{ // DispatchPower
#if DBG
PIO_STACK_LOCATION stack = IoGetCurrentIrpStackLocation(Irp);
ULONG fcn = stack->MinorFunction;
static char* fcnname[] =
"IRP_MN_WAIT_WAKE",
"IRP_MN_POWER_SEQUENCE",
"IRP_MN_SET_POWER",
"IRP_MN_QUERY_POWER",
}; if (fcn == IRP_MN_SET_POWER || fcn == IRP_MN_QUERY_POWER)
static char* sysstate[] =
"PowerSystemUnspecified",
"PowerSystemWorking",
"PowerSystemSleeping1",
"PowerSystemSleeping2",
"PowerSystemSleeping3",
"PowerSystemHibernate",
"PowerSystemShutdown",
"PowerSystemMaximum",
}; static char* devstate[] =
"PowerDeviceUnspecified",
"PowerDeviceD0",
"PowerDeviceD1",
"PowerDeviceD2",
"PowerDeviceD3",
"PowerDeviceMaximum",
}; ULONG context = stack->Parameters.Power.SystemContext;
POWER_STATE_TYPE type = stack->Parameters.Power.Type;
KdPrint((DRIVERNAME " - IRP_MJ_POWER (%s)", fcnname[fcn]));
if (type == SystemPowerState)
KdPrint((", SystemPowerState = %s/n", sysstate[stack->Parameters.Power.State.SystemState]));
KdPrint((", DevicePowerState = %s/n", devstate[stack->Parameters.Power.State.DeviceState]));
else if (fcn < arraysize(fcnname))
KdPrint((DRIVERNAME " - IRP_MJ_POWER (%s)/n", fcnname[fcn]));
KdPrint((DRIVERNAME " - IRP_MJ_POWER (%2.2X)/n", fcn));
#endif // DBG
NTSTATUS status; pdx = (PDEVICE_EXTENSION) fido->DeviceExtension;
PoStartNextPowerIrp(Irp); // must be done while we own the IRP
status = PoCallDriver(pdx->LowerDeviceObject, Irp);
return status;
} // DispatchPower ///////////////////////////////////////////////////////////////////////////////
{ // DispatchPnp
ULONG fcn;
NTSTATUS status;
// Handle usage notification specially in order to track power pageable
// flag correctly. We need to avoid allowing a non-pageable handler to be
// layered on top of a pageable handler.
if (fcn == IRP_MN_DEVICE_USAGE_NOTIFICATION)
{ // usage notification
if (!fido->AttachedDevice || (fido->AttachedDevice->Flags & DO_POWER_PAGABLE))
fido->Flags |= DO_POWER_PAGABLE;
IoCopyCurrentIrpStackLocationToNext(Irp);
IoSetCompletionRoutine(Irp, (PIO_COMPLETION_ROUTINE) UsageNotificationCompletionRoutine,
(PVOID) pdx, TRUE, TRUE, TRUE);
return IoCallDriver(pdx->LowerDeviceObject, Irp);
} // usage notification // Handle start device specially in order to correctly inherit
// FILE_REMOVABLE_MEDIA
if (fcn == IRP_MN_START_DEVICE)
{ // device start
IoSetCompletionRoutine(Irp, (PIO_COMPLETION_ROUTINE) StartDeviceCompletionRoutine,
} // device start // Handle remove device specially in order to cleanup device stack
if (fcn == IRP_MN_REMOVE_DEVICE)
{ // remove device
IoReleaseRemoveLockAndWait(&pdx->RemoveLock, Irp);
RemoveDevice(fido);
return status;
} // remove device // Simply forward any other type of PnP request
return status;
#pragma PAGEDCODE
VOID RemoveDevice(IN PDEVICE_OBJECT fido)
{ // RemoveDevice
PDEVICE_EXTENSION pdx; KdPrint(("Enter RemoveDevice"));
PAGED_CODE();
#pragma LOCKEDCODE
{ // StartDeviceCompletionRoutine
if (Irp->PendingReturned)
IoMarkIrpPending(Irp);
// Inherit FILE_REMOVABLE_MEDIA flag from lower object. This is necessary
// for a disk filter, but it isn't available until start-device time. Drivers
// above us may examine the flag as part of their own start-device processing, too.
if (pdx->LowerDeviceObject->Characteristics & FILE_REMOVABLE_MEDIA)
fido->Characteristics |= FILE_REMOVABLE_MEDIA;
return STATUS_SUCCESS;
} // StartDeviceCompletionRoutine ///////////////////////////////////////////////////////////////////////////////
#pragma LOCKEDCODE
{ // UsageNotificationCompletionRoutine
// If lower driver cleared pageable flag, we must do the same
if (!(pdx->LowerDeviceObject->Flags & DO_POWER_PAGABLE))
fido->Flags &= ~DO_POWER_PAGABLE;
} // UsageNotificationCompletionRoutine #pragma LOCKEDCODE // force inline functions into nonpaged code
#pragma LOCKEDCODE
NTSTATUS status;
// KdPrint((DRIVERNAME " - Enter DispatchForSCSI /n"));
irpStack = IoGetCurrentIrpStackLocation(Irp);
IoSetCompletionRoutine( Irp,
USBSCSICompletion,
NULL,
TRUE,
TRUE,
TRUE );
return status;
